I worked this card with the NEO software which is supplied with it, but it gives bad results.
The problem with this card is that with other software sometimes it works and sometimes it won't show the video. I tried Virtualdub which worked perfect but intermitently, some other software like vegas or iuvcr it does the same.
What is wrong?
Izzy
I have one that seems to work just fine with VirtualVCR, and gives very good results. You might give it a try.
I've had excellent results with iuVCR and this card, and decent results with Virtual VCR (although the audio sync is tighter with iuVCR on my system).
maybe it's a problem with your card, or your settings? check Lordsmurf's website, www.digitalfaq.com - he's got a guide that I wrote for him on my EZ Dvdmaker / iuVCR method.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
