I had converted a few fansubbed anime into mpeg 1 format, for viewing purposes on my tv. However, the vcd played on my tv has the subtitles cut off. May I know what is the reason, and what must I do to avoid this from happening? RIght now, the image is cut off at the top and bottom on my tv.
Thanks alot
Yes, that's how how it works. It's called overscan, and completely baffles every noob.
All TVs does this, and the way to avoid important stuff getting cut off, or left out of the picture alltogether, is to move it closer to the center.
If the subs are permanent, only solution is to add balck borders top and bottom (and even left & right, 'cos thsese sides get cut off too) when encoding. How to accomplish that, depends on your method of converting ??? to mpg1.
/Mats
For more on the subject: Search for "overscan" -
oh, so that's the problem. thanks for the reply. I'll do a search for it then.
Subtitles in Final Cut or other software?
By perik in forum SubtitleReplies: 2Last Post: 10th Dec 2009, 08:02 -
How do I cut TS file and keep Teletext/DVB subtitles ???
By boulder in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 18:50 -
Final cut pro and subtitles
By akiraku in forum MacReplies: 7Last Post: 6th May 2009, 17:31 -
Subtitles cut off on tv. More than just overscan?
By rayden54 in forum Newbie / General discussionsReplies: 9Last Post: 13th Feb 2008, 11:20 -
Subtitles getting cut off
By shockaholic in forum Video ConversionReplies: 2Last Post: 25th Oct 2007, 10:05
