I am newbie for video convert. my friend send me a SVCD MPEG file
and he said it is ready to burn as a SVCD. but I found the screen need
to crop 2 or 4 lines on the top. could you tell me how to crop the MPEG
files and do not encode the file againg using TMPGENC? thanks.
Pretty sure this can't be done, you'll have to re-encode.Originally Posted by cxterm"Art is making something out of nothing and selling it." - Frank Zappa
That's too bad. It will take a long time to reencode
the file. Will the reencoding reduce the video quality?
Thanks, ZippyP -
Yes it will decrease the quality. Why do you need to crop the top? Is it off center? If you play this on a hardware dvd player then the outer portions of the picture won't be visible anyway due to overscanning. I'd go ahead and just try burning it. Use a cdrw if you don't want to waste a blank.
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
Magix movie edit pro 15 burn problems
By wolfspirit1964 in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:10 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
SVCD edit
By monarols in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 18:48 -
Magix Movie Edit Pro DVD menu problems
By dave_ryman in forum Authoring (DVD)Replies: 4Last Post: 3rd Aug 2007, 00:40
