  1. I want to extract the time of each scene change from AVI files I have on my computer and have it put into a text file along with the AVI... right now I have to highlight the text beside each scene in Pinnacle, then copy it into a text file to make my menus before encoding to DVD... major PITA factor.
    Any ideas?
    Apr 2002
    The State of Frustration
    Reduce the pucker factor with DVTimeStamp.
    Hello.
  3. Thanks for the reply, I will look into it, in the meantime I found a freeware proggy called Scenealyser at
    http://www.codecpage.com/Links.html with a bunch of other DV freeware and software
    This one works quite nicely and will also split a DV file into multiple DV files based on the timecode, may be handy if you have a bunch of small clips that you want to use as stock footage or something along that lines... and will save them with their file name as the timecode
    Sep 2012
    Maroc
    hi everybody,
    i need extract datetime of each frame of avi video, in excel or text file,
    i don't know if that possible?? someone can help me
