Women want shrinkage, that's why Chinese Shrink Cream sells so wellOriginally Posted by Sabro
It's the men that fear shrinkage
Closed Thread
Results 31 to 60 of 109
Let's think about it logically, shall we ?Originally Posted by Jah_Rankin
I would think it does is a direct stream copy if you like of the main movie, just like IFOEdit or Smartripper or DVDDecrypter or any other software would. It reads the IFO file and copies the cells. I wouldn't think it applies any filters or anything on the movie.
Have you had better results using something like DVDDecrypter or Smartripper ?If in doubt, Google it.
I'm not sure what the conversion process insist of but i know what my eyes can tell. My theory were clearly demonstrated in the snapshot posted earlier with the dark looking skin tones.
Originally Posted by jimmalenkoLive Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
If I release a product It will not be free for cheap rug rats like to utilize, spend some $$$ cheap bastard. The so called free apps is good for what it's worth, but the pic quality is still lousy as far as I can tell.Originally Posted by hech54Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
pot-kettle-black ?Originally Posted by Jah_Rankin
Is this the picture you wer referring to ?
I am guessing that the top one is possibly the shrunk one according to your theory of darker skin tones. Don't forget this one was at 60.1% compression, whereas you claim that yours is happening at 100% (No compression).If in doubt, Google it.
Jah_Rankin, could you let me know exactly how your "theory" was demonstrated?Originally Posted by Jah_Rankin
well i too am a cheap bastage and enjoy the time and effort and time put in to a prgram that i can use for free. so that i dont confuse anybody i suggest that if you want the best possible copy that you have 2 options. 1. spend a little $$$$ you cheap &*^%$# and buy the orignal or 2. buy yourself a dual layer burner with dual layer media and do a 1:1 with out any transcoding or compression. i think that my be your best option but then again thats just my dvdshrink 2 cents.
@ddlooping:
I too can tell that the skin color is darker in the top picture. However I believe this is because it was at 60.1% compression. I would like to see the frame comparision using no compression (no compression = original?)Originally Posted by jimmalenkoIf in doubt, Google it.
Sorry, Jah_Rankin, I still don't get it.Originally Posted by Jah_Rankin
According to your theory, the top one shows black undertones, and is from the DVD Shrink backup?
I'm outta here. You can't talk sense to someone that can't talk sense themselves.
If they didn't need compression then why didn't you just use DVD Decrypter in ISO read/write mode?Originally Posted by Jah_Rankin
DVDshrink is free and you used it, so by your definition..you are a cheap bastard
You're always going to get better results if you use the proper programs for the job at hand.
BJ_M, just out of curiosity, why does the top edge of Gandalf's left shoulder look better to you?
there is a slight raggyness in the original that was not in the backup in that one spot -- also , there is a thread which shows in the backup but not to much at all in the original - which i find rather strange ...Originally Posted by ddlooping
you sure you didnt reverse these ?
it may of been caused by the resizing and compression for the web .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I'm sure I didn't reverse the pictures.
Not sure why there'd be a thread showing in the DVD Shrink version and not the original.
Maybe it's actually a compression artefact and not a thread.
not for nothin, but dvd shrink is THE BEST copy software i have ever seen. dvdxcopy can't eve touch shrink with a 10 foot pole. there are none better and the new 3.2 is even better.
i dun know what jah is smokin but what ever it is, it isn't any good for his eyes.
I don't think Jah is smoking anything. Maybe he should be! 8)
DVDShrink is brilliant.
No, I don't use it to copy "Lord of the Rings" etc... I use it when TMPG DVD Author tells me my project is oversize, so I shrink it down to DVD size!
PERFECT quality!!!!!!
i thought dvd2one is supposed to be slightly better quality , i don't know myself ..
some people swear by one , some by another ..
how do you compare the two ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
You make backups of the same title, using identical compression ratios, then you watch them.Originally Posted by BJ_M
You do the same with different titles, then pick the one that gives you better results overal.
Oops, I guess I misunderstood you.
You could always compare using the following.
Most of the work has been done for you.
http://www.dvdshrink.info/temp/beta/comparative_tests.html
These test were done with DVD Shrink v3.2 beta3.
Others are available (see links on the page) but do not involve DVD2One.
The results of the v3.2 b3 tests told me all I needed to know.
P.S: keep in mind there's been a noticeable improvement between v3.2 b3 and v3.2.0.15
You're welcome.
Dude, you know what's hilarious? You never, in all 5 or so of your posts talking about the obvious differences between the two pics, specified WHICH of the two pics was the one with these discolorations. This leads me to believe you really couldn't tell (as I couldn't tell) which pic was from the original and which one was the compressed video. Maybe with a lot of analyzing you could see the difference, but it's definitely not obvious, and very impressive at 60% compression. Although I do think you can't do a real comparison based on still frames. You have to see the video playing to really test the quality.Originally Posted by Jah_Rankin
I too have thought the same thing as Jah_Rankin before when simply taking the main movie from a DVD and leaving it uncompressed. However, this always happens when playing it in PowerDVD on my computer. After playing the original, also on my computer, I realized that DVD's just don't look that great when viewed close up on a computer monitor. When played on a regular television, I get the picture that I'm used to. No compression = no change, right?
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
Shrink DVDs without losing much quality
By ssusca in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2011, 13:57 -
DVD shrink vs DVIX video quality
By sportflyer in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2008, 21:31 -
How to shrink DVD9 to DVD5 with no Quality loss?
By CERO in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2008, 07:18 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
