Hi all, I got a home movie that was burned to dvd, its one whole scene, ive got it out of the vob format to i guess raw mpeg2, what program can i use to break it down and just make the scenes the lenght I want. thanks in advance.
Mpeg2Schnitt works quite well if it accepts the file. It is sometimes picky with regards to what mpegs it will take. Are the audio and video separate (elementary streams) or is it sound and video in one file (program stream) ?
If it's one video file you click on that also contains the sound, its a program stream. TMPGEnc's cut function works well in this case.
If the video file plays without sound and theres a separate sound file, you can cut this using Mpeg2Schnitt. When there's a separate audio file and video file, for example, Video.m2v and Video.ac3, those would be called elementary streams. Mpeg2schnitt cuts these nicely and you can add them separately. -
If you can't get Mpeg2Schnitt to accept the file, try cuttermaran. Its basically the same, only you have to download tmpgenc too.
Avidemux - Why is there pixelation from stream movie?
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2012, 11:20 -
Scene It?
By jwfc in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2008, 11:32 -
automatically cutting a large wav file into x minute chunks?
By graysky in forum AudioReplies: 5Last Post: 22nd Sep 2007, 23:12 -
cutting a scene from the subtitle
By a7medo778 in forum SubtitleReplies: 8Last Post: 31st Aug 2007, 04:24 -
cutting a large WMV - audo/video sync is off
By djbryson in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
