Is there a free program similar to the one included in Nero for making Dvd Covers? I just want to import my bitmap into the program and print. The main reason I need this is so that it sizes the image correctly, and I just put it on A1 paper which is slightly longer than a standard letter 8.5x11. Is there such a program? Thanks.
Yes, you can download ExPressit 2.1 SE for free.
http://www.medeainternational.com/pressit/
This is the program that comes with Memorex DVD case label packs.
I just bought the 3.0 SX version off their website last week. (It cost me $10.78 when converted to US dollars.) It has several new features such as ability to edge outline text, shadows, shapes, transparency, etc.
I think its a good little program for doing labels. You might just download the free version, 2.1 SE first and get the new one if you need the extra features.
Be warned though that the new version (3.0) doesn't seem to be able to open the old 2.1 SE files. -
The gimp will do that too. Go to image>scale, change the display print properties to the correct size in inches.
The gimp will do that too -
Originally Posted by Garibaldi
not sure if it's in your budget, but I recently bought the epson R200 that prints directly onto inkjet printable cd/dvd's and am very impressed with the quality. No more labels and it comes with a nice little program for printing.
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 04:20 -
dvd cover desing
By ht0160 in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2010, 15:54 -
How do I print out a DVD cover?
By orfajackson in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 14:33 -
dvd cover to icon
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2009, 11:21 -
Different AR on IMDb and DVD-cover
By tominator in forum Newbie / General discussionsReplies: 4Last Post: 26th Mar 2008, 07:47
