I have a DVD that, when I play it, is black & wihte.
I know this is because it is a NTSC disk and my player can't convert that signal to PAL.
Is there a way to backup the disk to PC and convert the entire DVD, menus and all?
DVD2SVCD will convert it to PAL, or it could be done by running it thru DVD2AVI, and re-encoding as PAL and re-authoring (I dont think you will be able to keep any menus or extras whichever way you do it). Converting the Video is dead easy, its the AC3 audio you are going to have problems with. Most freeware AC3 transcoding tools use the Besweet/Ffmpeg engine, which is not 100% DVD compliant. Some players are OK with the output, but others aren't. You're only other option is to buy a commercial AC3 encoder, but it would be cheaper to buy the region 2 disk...
I thought as much.
I was just hoping there was a less painful way to do it.
The DVD is region 0, region free, and purchased of the shelf in Sweden,, so you'd think they'd encode it in PAL, but I guess the producers of cheap porn don't think that far.
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
HP Vista Ultmate 64-bit wanting to convert entire DVD library
By theruckman in forum DVD RippingReplies: 3Last Post: 11th May 2009, 19:48 -
Can't convert entire DVD to DV AVI
By Jerry1964 in forum DVD RippingReplies: 12Last Post: 17th Aug 2008, 10:45 -
ConvertXtoDVD doesnt convert entire file
By rperson989 in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2007, 06:16 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
