I have an .AVI and the subtitles are in a .SUB file. How do I burn the subtitles into the AVI, preferable as fixed (=witten into or just below the movie)?
Any help is appreciated.
Results 1 to 16 of 16
major wrote:
1. By opening your file, loading the subtitles file in the Filters tab ("Load subs"), selecting DivX preset, and hitting "Encode"
2. If it is .idx/.sub (VobSub format), try to load the .idx file.
*sigh* I really thought point 2 was the key for me too. Sadly not. I've been tryng nonstop for two days now to burn subtitles into a .avi file, and obviously keep the sound. Try as I might, I can do one, but not the other.
What has broken my spirit on this is that using the Preview button in the Filters tab, both sound and subtitles are just fine. The subtitles don't show up using the main Preview button though, the one to the right of the Save As... filename at the top of the window. How can this be? Only major can save the day...
Here is the information at the top of the main window on the file:
mpeg4, 640x272, 23.98 fps. AUDIO: ac3, 48000 Hz, 5 channels, 384 kb/s
And here is the information from the Info box for the (partially) encoded file:
Encoding started on Sun Sep 12 22:56:03 BST 2004
MEncoder dev-CVS-040904-19:44-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
success: format: 0 data: 0x0 - 0x2bc35800
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
AVI file format detected.
VIDEO: [DIVX] 640x272 12bpp 23.976 fps 1709.8 kbps (208.7 kbyte/s)
Using AltiVec optimized IMDCT transform
[V] filefmt:3 fourcc:0x44495658 size:640x272 fps:23.98 ftime:=0.0417
Opening audio decoder: [liba52] AC3 decoding with liba52
AC3: 5.1 (3f+2r+lfe) 48000 Hz 384.0 kbit/s
Checking for AltiVec resampler : 0x0000000a, 2
AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 48000->192000 (384.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=640 h=272]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Using AltiVec optimized resampler
SUB: Could not determine file format
Cannot load subtitles: /Users/gavin/Movies/Title.1/DISC_1/Title.1.1.idx
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
MP3 audio selected
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 640 x 272 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 2.35:1 - prescaling to correct movie aspect.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (640x272 fourcc=58564944 [XVID])
To sum up: Help!
PS I get the same "Could not determine file format Cannot load subtitles: " message in the Info whether I try to load the .sub file or the .idx file. They are definitely readable using the Filters Preview button though, so they aren't dodgy files as such.
Why not just load the video into Virtual Dub, add the TextSub filter, load the .sub file into the TextSub filter, and save under a new file name?
Hello.
Thanks for the suggestion - looks a great app - but I'm on Mac OS X, and sadly Virtual Dub seems to be Windows onlyOriginally Posted by Tommyknocker
If major says there's a problem here, then I might try cranking up Virtual Dub in Virtual PC on the Mac, but the chances are such an intensive application would grind to a halt
Sorry, when I saw the VobSub references, I put two and two together and came up with five.Originally Posted by midwichHello.
I tried going down the virtualPC route, but have been driven mad by VobSub's whining about AviSynth not in the right place or something. It's in C:WINDOWS\SYSTEM where its installer put it, but VobSub doesn't like it. Typical
Does anyone know the solution to my problem with ffmpeg - should I start a fresh thread the better to attract major's attention?
A solution of sorts: Plan C was to download MPlayer for Mac OS X, as unlike VLC it's supposed to be able to deal with .sub files - and it can! I'd heard bad things about MPlayer on OS X, but I can't see why: it plays the movie with subtitles perfectly, at full screen too (DVI TiBook circa 2002 on 10.3.5)
I'd like to burn in the subtitles for safekeeping if someone can talk me through the steps for ffmpeg, but at least I can watch it now!
Hi, I also would like to know how to do this
I'm on MAC OS X Leopard 10.5.2
I have these files:
-rwxr-xr-x 1 liviu staff 733900800 Feb 15 15:58 dmd-awake.avi
-rwxr-xr-x 1 liviu staff 291914 Feb 15 16:05 dmd-awake.idx
-rwxr-xr-x 1 liviu staff 20418560 Feb 15 16:05 dmd-awake.sub
For burning in idx/sub subtitles see
https://forum.videohelp.com/topic345487.html#1810387
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
burn subtitle and font size
By sneike in forum ffmpegX general discussionReplies: 10Last Post: 6th Oct 2008, 16:02 -
Burn IDX Subtitle ONLY to CD With AVI
By stoneferry in forum SubtitleReplies: 4Last Post: 22nd May 2008, 02:13 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 10:02 -
nero burn plus subtitle?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 31st Aug 2007, 22:57
Did you want me to send the offending .sub file for example? It's 6.3Mb so not too bad. I'd guess any .avi that you have lying around that has the broad characteristics of mine (see earlier post) would do.
