  1. With bitsetting supported by the new firmware version (A104), isn't LG 4020B one of the better DL wirters in the market?
  2. Is that 4120B? I don't have any prior experience with burners, but I love mine. Reads and records to everything and is very quiet, can't even hear it. Came with a fair amount of software even. Only drawback is it doesn't take RAM cartridges.
  3. Originally Posted by samijubal
    Just remove the DVD-RAM cartridge, not bad at all.
    Using one double-side DVD-RAM for temp. storage, seem to be good and reliable so far.
    Just a bit slow.
  4. They are easy enough to take out of the cartridge, but most of my RAMs are Optodisc and removing them from the cartridge voids the warranty, which I have had to use in the past for replacement of bad discs. That's why it's a disadvantage that it doesn't take the cartridges, for me anyway.
