I want to keep all the trailers for my DVDs on my hard disc drive and have started to rip them from my DVDs, however I am finding it difficult to locate them. Once found I rip using DVD Decrypter and use the VOB with zoomplayer, it all works fine. Is there a tool or method that will allow me to play a DVD as normal but to see which VOB it is playing? Steve
The method I use is I navigate to and play the trailer in question using my dvd player software and take note of the running time.
Then go into DVD Decrypter and hit the I key to start up IFO Mode, and look for the PGC that corresponds to that total running time. From there you can demux into elementary streams or do a direct stream copy.
This works most of the time. Others may have better methods -
Yes DVD Shrink Version 3.2 is most current. Great tool and my number one tool for doing most of My DVD work.
I use WinDVD to locate the track the trailer is on. Then use DVDShrink in the re-author mode, drag the track to the left and then click Back-up.
Use can also use DVDShrink to locate the track, but if there are a lot of tracks it can be time consuming.
Movie Trailers?
By xxnonamexx in forum EditingReplies: 4Last Post: 5th Nov 2011, 15:02 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 12:57 -
Do these trailers play for you
By disturbed1 in forum Off topicReplies: 1Last Post: 18th May 2009, 12:54 -
In a world... where no trailers will be the same...
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 4th Sep 2008, 22:51 -
PS3 Trailers .AVC
By george559 in forum Blu-ray RippingReplies: 1Last Post: 19th Mar 2008, 12:41
