Hello All,
I am evaluating the TMPGEnc DVD Author program and seem to be having problems at the point where I try and write to the media (DVD-RW) when I select my external FW Pioneer A06 DVD burner. The error I get is as follows with the option to send Microsoft a report:
DVD Writing Tool has encountered a problem and needs to close. We are sorry for the inconvenience.
I seem to be able to reproduce the problem using either version 1.5 or 1.6 of the program. I have sent TMPGEnc an e-mail for some help several day back but no reply as of yet...
Any help or pointers would be greatly appreciated as my burner works flawlessly with other programs and this one is very puzzling. Unless I am not doing something right which is always possible! 8)
Cheers,
Vin.
I often have problems with TMPGEnc's DVD Writing tool, whether it's the same problem you have, or buffer underruns (even though my burner has buffer underrun protection), or an "invalid unit number" error message. I've said the hell with it and just use Nero to do the burns.
If you don't want to pay for another program to do your burning, try IMGtools Classic and DVD Decrypter. -
yep, just burn the video_ts folder with another tool. guides:
https://www.videohelp.com/author#3;25 -
Appreciate the comments and help - Yes, I will probably use another tool to actually butn the video but it would have been nice to be able to do this all from within one application as the product claims to be able to do this!
Thanks all...
Vincenzo. -
I've never had a problem with TDA'a burner on my system. I rather like it myself because for some unknown reason it burns my cheapo Princos at 4x when everything else I have burns them at 2x only.
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 05:14 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 03:40
