Results 1 to 9 of 9
  1. Member gooberguy's Avatar
    May 2003
    WNY, USA
    Everytime i start my computer a enternet explorer window opens up and in the adress bar come " http://clicks.spazbox.net/mt.html " this is very annoying, and was wondering if anyone knew what was going on and if they know how to stop it? anyways i checked msconfig, and nothing seems out-of-the-ordinary there.
    Thanks in advance
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Download Spybot Search & Destroy from ZDNet download area. It is free and has excellent online updates every couple weeks. It seems to get all the nasty little bugs we get online
  3. Member Reaper88's Avatar
    May 2003
    I have found that spywearblaster is a nice little program that hepls block sywear before it even gets on your system
  4. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    The new Ad-aware is nice also. Run it in Safemode for extra removal goodness.
  5. Member gooberguy's Avatar
    May 2003
    WNY, USA
    i actually use ad-aware 6.0 wit latest updates, that doesnt seem to be working though. (at least for this) it works good for others
  6. After the Spybot & Adaware scans (and get the new AdAwareSE - it finds more than 6.0 does) look for a file called asetup32.exe at the root of C:. If it's there, get rid of it. If that's still no good, DL "Hijack This" and post a log to a spyware forum like the one at www.spywarewarrior.com. There are several of these, and the experts there can tell you what you need to manually clear out of your registry.
    Also, the freeware Spyware Guard & IE Spyad are good preventative measures in addition to those already mentioned.
    Using Firefox or Opera IS a good idea, but you can likely fix this without doing that or a reinstall.
  7. Member gooberguy's Avatar
    May 2003
    WNY, USA
    Thank you all for all the info. I did have that assetup32.exe file and deleted it, i am now using HJT. I was wondering what was that assetup32.exe file?
  8. just put the name of it in the search at http://www.google.com/
    you should have an answer
