I'm asking in terms of writing quality and 8X media compatibility. I don't care about firmware hacks and the like.
As always, thanks for your input.
Unless you are getting either for less than $50, I'd look at the SOHW-1213S or the DVR-108. The 1213S runs almost the same price as the 812s, and the 108 is just under $100. I chose the 108 based on my great experience with the 106 and 4x+DL. It should be here in a few days. Lots of happy forum members use Pioneer drives, just do a search.
Best of Luck,
-Evan- -
Dual layer media will be very expensive. I'd wait until prices of dual layer media come down. I wouldn't want to pay $10.00 a disc. If you can afford dual layer media then purchase the Pioneer 108. The Pioneer 107d is a good drive. It'll be put on my next computer that will only do video editing. Lucky I have a Antec computer case where I can easily remove my optical drives. No screws need to be removed the dvd burners slide out easily. I'd suggest you purchase a 107d but remember it's reading 2x speed is locked. In order to rip dvds at a faster speed you would need to use the hacked firmware. Or just get a dvd-rom to rip dvd files.
Thanks for the info - I could care less about dual layer: I'm not paying $10 for a blank disc, that's just plain crazy. I can wait 2-3 years for the prices to drop. As for DVD ripping, I always use a DVD-ROM. The price difference between the 107 and 108 at Newegg is only $14, so there's a big incentive to go with the 108. Dunno now. Decisions, decisions...Originally Posted by budz
Even if you're not doing DL, the 108 does 12x and 16x on SL media vs 8x on the 107. I'd say go for the 108.
Nothing can stop me now, 'cause I don't care anymore. -
OK, I ordered the 108 and should get it within a few days. Thanks.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38 -
TYG03 burns at 18x in DVR-112D, only 4x in DVR-107D
By mikewillnot in forum MediaReplies: 1Last Post: 15th May 2007, 17:28
