  1. i am using dvdshrink 3.2, and i want to backup the entire disk, but under the "main movie", it shows Title 3 and title 4, both being the exact same thing. both widescreen. i went to view, and unchecked "combined shared titles", so i could edit one of the titles at a time.
    but... whatever i do to title 3, the same happens for title 4.
    how do i remove title 4? (dont want to use re-author because the menus will disappear)
    Mar 2004
    Southern California
    I don't think you can do this with shrink. You might try VobBlanker, DVDStripper, or DVDRemake. Look here
    https://www.videohelp.com/tools?s=19#19
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    if you cannot split them then maybe they use the same VOB's and the PGC's are just duplicated cells in the IFO's
    open the IFO in Ifoedit and see what VOB ID's the movie uses. You want to check to see if any VOB ID's or Cells are linked
    If they are then removing one cell may affect the other movie. Lion King is an example of this as the Special edition uses all but 2 cells in both versions of the movie
