  1. I have a.mov file that i want to play on my dvdplayer. I converted the file with compressor but only got a .m2v file and no sound file. so i extracted the sound file .aif, from the original.mov file. how can i join the two into one synced file?
    thanks in advance
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    You can use the freeware Sizzle to import the audio and video tracks, and it will then master a DVD folder for you. If you want to save space, you can compress the .aif file to AC3 format, and use that with Sizzle (or DVD Studio Pro).
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
