Hey guys,
I'm trying to take a DVD that is two sided and put it on one DVD-R. I don't care about keeping the extra stuff on it but like the menu selections and would like to keep those. I think I might be able to do this with DVD Decrypter and DVD Shrink but can't figure out how. Can anyone here help me with how to do this?
please post dvd to dvdr in the dvd to dvdr forum. moving you.
read this guide
https://www.videohelp.com/guides.php?guideid=646&howtoselect=6;57#646
it wont work with all dvds. -
I also like to keep the menu and scene selection options from double sided DVD (DVD-9).
I find that DvdReMake is my best choice for hiding(removing) extras and then fixing the menus and/or navigation such that the removed extras can't be selected.
Other products can remove extras but usually leave menus that may or may not work.
I use the great DVDShrink to squeeze the results back to a DVD-5 size at very good quality.The OldeMan
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
How to put 2 DVD onto one, keeping menus?
By LCE in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2008, 01:37 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 10:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 04:04
