I just started using dvd shrink a few days ago and I have made about 5 coasters already. The program seems fine. I use it to rip and burn the movie useing the dvd decrypter and nero options under the burn tab. When I use the nero option, after all of the conversion have been done, it freezes up during the burn pocess. When I use the dvd decrypter option, everything seems fine. Then when I play it back in my stand alone dvd player, the menu comes up but it wont play the movie or any of the features. Does anyone have any advice? Do I need other software, updates, or drivers? I have the newest version of dvd shrink and am running xp. Thanks
Try using Dvd Shrink to rip and compress the files to the hard drive first. Then use Nero Ver.6 to burn outside of Dvd Shrink. I use Nero Express and tell it to make a Dvd Movie Disc. I have done this over 400 times and not one coaster yet.
If Man Made It, Man Can Copy It. -
sounds like bad media. what brand of dvd media are you using?
I have been using Shrink alond with Decrypter for the last month or so, and found it absolutley perfect. The last film I did was Kill Bill2, and with shrink I was able to keep the DTS sound as well as everything else (55% compression on the movie). Quality wise I can't complain at all.
Get Firefox now, death to Internet Explorer.
http://www.getfirefox.com/
http://www.spreadfirefox.com/?q=user/register&r=42857
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 08:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 21:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 12:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 09:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 11:21
