    Jan 2003
    Nassau, Bahamas
    when installing these things, http://www.pccasegear.com/prod759.htm, i can see that i put it over my heatsink for my cpu, now would i have to disconnect my heatsink fan, or would i just connect the duct ontop of my heatsink and fan, then install the other fan on top of that...does anyone know about this, or have one installed...holla back, i would like to try this.
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    From the looks of the diagram it goes between your heatsink and your fan. So you'd have to remove your fan from the heatsink and reattach it to the ducting mod. Even if you COULD attach the mod on top of your fan, it would defeat the purpose because they're saying the point of using it is that the fan prevents airflow directly to the center of the heatsink (where the fan head is).
    Nothing can stop me now, 'cause I don't care anymore.
    Jan 2003
    Nassau, Bahamas
    cool, i kinda figured that out after i searched soem more sites from google, the things is, i wonder if that do the trick especially being down here in the bahams, im always looking for more ways to cool my system besides ice!!!!!
  4. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I couldn't give you any links off the top of my head, but there are plenty of 'liquid cooling' kits out there if you're willng to try something different.
    Jan 2003
    Nassau, Bahamas
    if you can remeber a good one, plz find it and post the link for me, ill be happy to try it out, holla back
  6. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Liquid cooling isn't necessary unless you want to overclock. Occasionally it also can quiet a system down but proper air cooling can be just as quiet if not more so.
    Forget the ducting and look for magnetic levitation fans that will replace your current heatsink fans. Mag-lev fans minimize the hub area and are also far more quiet than ball-bearing fans. Aftermarket heatsink would also help. Look into Swiftech heatsinks with a good 80mm fan on top of it and you'll be good. That hub displacement issue won't matter much with one of those weighty copper slugs sitting on your processor.
