ok i just got the full version of svcd2dvd from www.svcd2dvd.com and i just converted one of the movies i got off the net, but what i was wondering was if there was actually a way if i can put a picture on the menu, instead of the name of the move? Im a newbie at this but it looks cool
Use the guide on svcd2dvd website to guide you though all the steps. It explains how to make a single movie, two three etc.. with and without menus etc..Originally Posted by t-dot
But to answer your question, after you select to rip bins, or not bins but mpegs, you would hit the author button and set up for one, two etc.. movies and select chapter times (see guide) then you would hit menu button and then load backgrounds tab. In version 1.51.2 I have 21 backgrounds to choose from. I think the website says there are 80 backgrounds.... I have been wanting to ask anybody else if they only have 21 selections. Apparently you can use your own picture as well. They are jpg format. If you go to the install folder and look in the background folder you will see the jpgs. They are all 720 x 576 size so I am thinking if you make your own you will need to resize them to that resolution for compatiblility but I am not 100% on that since I have not tried it yet. You need a photo editor like photoshop to do the job. There is also a font button to change the font type in the text.
Hope this helps. Pretty new to this app myself. The only complaint I have to this app is that this forum is not as active as I would hope. I guess it is pretty specialized and not too many use it? I know the developer does this as a hobby and appears to work on show stopper issues mostly. But I would still like to hear from Chrissy about the freezing issue that some have on the biginning of the movie where one can kick start it buy hitting the forward key. Even if Chrissy has no workaround I would like to know if development is aware of it and what theories they may have on the source of troubles. -
Missing backgrouds... Have a look at:
https://www.videohelp.com/forum/viewtopic.php?p=765875#765875
and
https://www.videohelp.com/forum/viewtopic.php?p=781094#781094
To get the picture menu you describe (i think i understand) you would customise the menu like HighDesert suggests in a image editor but you would still need a text "DVD button". I do this and have "play" as my text....
I have not seen this. I may meed you to upload some samples for me to take a look at. Can you email me about this.But I would still like to hear from Chrissy about the freezing issue that some have on the biginning of the movieSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Next time I see this I will email the log. I don't have the older logs anymore. I am still leaning on win 98se having a part in this.
As for making backgrounds, one can also use powerdvd or windvd to play back the mpeg and just hit the capture button to take a snapshot. After that, I use ACDsee to convert the bitmap to jpeg. I use paperport to resize and make sure the dpi is 72. This works good and most people have powerdvd and ACDsee so this is another way to do it. I use the older ACDsee but the newer version will probably be able to resize it as well. -
Sounds good.
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 05:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 08:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 23:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 16:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 17:50
