  1. Hello,
    I still have the same problem with FfmpegX 0.0.9o :
    I'm trying to encode a 3ivx file wih mpeg-4 sound to MPEG-2 (with Mplayer)
    I want to make a DVD. And need Mplayer to burn the subtitles.
    Mpeg2enc doens't seems to see the sound ! (mpeg-4)
    In the preview, the same problem : no sound.
    Here the process info, if you can help.
  2. Try to set audio track to 1 instead of 0. I will fix this behavior in the next release.
  3. Will try that. But in preview, still no sound
    Thanks anyway Major
  4. Changed audio track.
    Still the same error.
    I haven't this error with a previous version of FfmpegX.
    Tryed to extract the sound separately in AC3.
    Got a : "track 0.1 found, can't find track 0.2" error.
    Something like that.
    Is there a way to convert the AAC sound in AC3 ? FfmpegX seems to not regognize if converted in AIFF.
  5. There is an issue with mplayer and AAC. I'll probably fix that in 0.0.9q. Encode your sound separately with the preset "Movie audio to ac3".
