I did some video from my Hi8 camcorder
capped it at 640x480 interlaced upper field with PIC codec
Open it in Vegas and inserted some title pictures/pages between scenes and for chaper points. I made them using the same setting as the capped video within Vegas video 5. I then encoded the video to 352x480 using MainConcept plugin to make it DVD complient, but the title pictures/pages shrank on the vertical sides....Is there anyway to stop this?
In my editor there's a default behavior for how it handles images this can be changed by right clicking the image and selecting the image source options. Either stretch to fit screen, keep aspect ratio which is what yours is set too or keep aspect ratio no letterbox which will center the image full screen but any overlap will not be viewable. Oddly because your vertical video resolution is being cut in half the "the keep aspect ratio" will in fact skew the image on the final product because the video will be stretched vertically to fit the screen.
Hopefully your editor has similar options, switch it to stretch. If it doesn't you could also try resizing the images to 352x480 but I don't know how the video editor is going to handle them.
Can't Stop Magnavox DVD Recorder TITLE Page from Playing Recording
By Novice20 in forum Newbie / General discussionsReplies: 19Last Post: 7th Sep 2011, 11:00 -
No picture using DVI page on pc
By Humbug in forum ComputerReplies: 7Last Post: 2nd Feb 2009, 07:18 -
Barely legible home/title page
By cyflyer in forum FeedbackReplies: 6Last Post: 25th Apr 2008, 06:05 -
Printer just stops if I add image, picture to page.
By NiteLite in forum ComputerReplies: 6Last Post: 26th Jan 2008, 06:37 -
Import picture/title into AVIsynth
By jwfc in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2007, 19:47
