I just got an archos video player and it is great. I use VirtualDub to convert my mpeg files. I use the Divx 5.2 Codec for Video, and the Lame MP3 audio codec..set at CBR 128kbs.....44 HZ setting (the one that is usually recommended for near cd quality)....
When I play my files back, I hear soft sqeaking noises, like someone scratching their fingernails against a chalkboard. It's not loud..but annoying...and this isn't in the original mpeg file. does anybody have any recommendations?
To me 128kb/s sounds like a transistor radio being played underwater.
Try the maximum bitrate possible and see if it improves.
Also try PCM and see if the noise disappears. -
PCM is uncompressed audio.
If I was using virtual dub it is shown as uncompressed audio. Essentially it is WAV file so it is a big file but that's what I have to do to get rid of the underwater gurgling sound.
However I have noticed that MPG2 source files or files ripped from DVD's that have audio encoded as MPG can also have this problem although not obvious. -
Yeah..I can make it uncompressed audio...but I have a 20 gb player and want to fit as many videos as possible on this thing. I wish it played MPEG, otherwise, the Archos av400 is the geek gadget of the century.
noise where joined 2 avi files
By coyote2 in forum EditingReplies: 20Last Post: 13th Oct 2011, 21:19 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
How to reduce Noise on AVI files?
By Nitro89 in forum RestorationReplies: 2Last Post: 8th Oct 2007, 18:29
