Is there a decent freeware/shareware DVD authoring tool available that allows for motion-menu's and motion-button's? I know you get what you pay for, and the freeware I have seen all have minimal tools available and no motion. I currently use a version of ULEAD DVD-Workshop which allows 5-second motions. perhaps I should just bite the bullet and upgrade, as I do find the ULEAD easy to use
I downloaded and tried the DVD-Lab 1.4 files, and tried creating a DVD. Once I got used to it, I liked the way it work and the interface. I created my DVD with motion menus, background image an dmusic, and then went to create the DVD files. The process created the proper VTS_01xxx.vob files for the movie but nothing else - no menus or anything else.
Patrick -
DVDAuthorGUI, and I think DVDStyler & GUI for DVDAuthor are all freeware and allow for motion menus. You will most likely have to create the menu with another program, but i think they all now support it. I am certain DVDAuthorGUI does.
Hope this helps.
Have fun stormin' the castle!
RogThere are many ways to measure success. You just have to find your own yardstick.
Freeware dvd author Request
By vhsreject in forum Authoring (DVD)Replies: 5Last Post: 31st Aug 2008, 16:40 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 21:45 -
Found an excellent freeware DVD copy tool...
By Djard in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2008, 20:17 -
DVD Motion Menu Buttons (Free & Easy)
By ImaWeTodd in forum User guidesReplies: 31Last Post: 28th Jan 2008, 17:12 -
What is the best freeware tool to convert a DVD to iPod?
By xoADAMox in forum Newbie / General discussionsReplies: 6Last Post: 8th Jun 2007, 22:18
