ok guys
i converted an avi with tmpgenc and eventualy burnt with no probs to dvd but without sound darn it , yeah i didnt check along the way
ok so i ripped the audio out with vdub mod from the original avi and turned it itno ac3 then mixed it back in to the already created mpg file ,. but when trying to load it into tmpgenc dvd author , the programe just sits and does nothing , like its trying to load the file but nothing is hapeninmg , also the file length in gspot of the mpg is way bigger than the actual length of the mpg , something like 4.5 hrs long , not 1.5 hrs which it should be
how do i correct this , its odvious the audio is throwing things out , maybe i should use one of the mpeg tools on tmpgenc to create a new mpg , but which tool and which setting , program vbr ? im not very familiar with these bits of the prog
anyone help please
