Hello Everybody:
I'm capturing off of my TV Monitor & my picture is perfect on my TV screen, on my computer screen & even in my WinFast PVR screen that I view the movie on. I have all three adusted to very close to the same quality picture.
When I play it back it's milky, it's a little too bright & it appears not enough contrast.
Does anybody have any ideas on how to correct this?
Thank You for Your Time!
DJ5A
The video should appear darker on your monitor. Don't adjust them so they all look the same but so the video on your monitor is slightly darker than your TV.
Sorry, I left out something.
If I convert & burn to DVD, it's fine except it's a little to bright & appears to need more contrast. (Milky)~~~~~~~~~~~~~~~~
DJ5A
You can change the settings in Winfast PVR that will effect the capture.
I did change settings in PVR & it appears to be working right but...
While viewing the PVR capture window it's very very Dark, in fact hard to view. So it's leading me to think I need to do something else...
I think I might need to get another set of eyes locally to look at it. Maybe I have the TV to bright? The rest of family (3) says the TV pic looks great.
The way I was told to adjust the brightness is to view a normally lighted view, look at some black clothing & raise the brightness until I can see the wrinkles in the clothing. LOL, maybe I need to try another method?
Any suggestions? I'm all Ears!
DJ5A
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
winfast PVR3000 Deluxe Remote Control problems
By teejayh in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 15:10 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
