I'm trying to reauthor a DVD I burned when I first got my drive, as it only has a basic menu on it (one of the default ones created using TMPGEnc DVD Author) and I'd like to make it a little 'prettier.' Now I've ripped the DVDR to my hard drive, the files are 4.35gig.. everything's fine there.
The problem is when I come to use TMPGEnc DVD author. I open a new project, go to "add DVD video" 3 times, to add all three tracks.. and it comes out saying that the size of the DVD is 4.575 gigs, and that it won't fit on the DVDR. What's going on there? I mean, I know there's a guide to reauthor the menu with DVD-lab pro, but it seems like this is something that TMPGEnc should be able to do. So basically I was just wondering if anyone knew why the DVDR is appearing to be over capacity, and if they do.. what could I do about it?
Hello,
Does it read larger after adding menus?? If so use less chapter marks and don't do motion menus (space hogs).
If it's just a reading error by TDA go ahead and author it anyway. Then go to dvd shrink and open the video_ts folder and shrink it. It should only be a minor quality loss since it almost fits a dvdr.
"and it comes out saying that the size of the DVD is 4.575 gigs, and that it won't fit on the DVDR. What's going on there?"
That's normal. take that output into any transcoder (DVD Shrink, etc.) for the "fit". -
The DVD shrink after re-authoring does work well.
But no that is not normal I don't think.
I have done this a few times and really it never happen yet. Course maybe your disk and my disks are not filled the same size.
Anyway have you just tried Add DVD video in the program and then let the program copy to the hardrive for you?
It will give you the option to work from disk or copy to drive, let it copy to drive, less chance of errors and it's faster, and if it copies the disk itself seems it should know the size too.
You could also rip the disk as movie only with DVD shrink, then re-author from there. Then you have the old menu stripped out to begin with and should be a smaller size, without shrinking.
SInce your talking about a DVD R and I dought you used a DL disk, there really should be no reason to have to shrink at any time, unless you add stuff! -
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 05:42 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
