I am attempting to convert MPEG-1 video files (I believe the mpeg-1 files must all be vcd compliant mpegs) of Ali G in da USA episodes into compliant files so I can watch them on DVD.
I have used tmpgenc xpress 3 to encode the MPEG-1 video files, and I have selected the template of "NTSC DVD" wit the appropriate aspect ratio (same as the source), since the source files are NTSC encoded.
The output is as 2 elementery streams, m2v and mp2.
HOWEVER, in the encoding process, TMPGEN Xpress 3 has converted the mpeg audio from 44000 to 48000. Is this going to be a problem? Should I have used the BeSweet method instead?
(BTW I'm having trouble checking the output files since my Media Player Classic is playing up... directshow filters maybe... thats another story altogether though hehhe)
Thanks guys
-dj simon l
djsimonl -
If you are converting to DVD compliant MPEG1 files then the audio SHOULD be 48000hz. It only needs to be 44100hz for VCD.
the audio file IS 48000hx...
my question is... I know that some tmpgenc apps are not as good as encoding as others (ssrc, besweet etc)
what i was asking is, will it be safe to encode the mpeg audio stream from the mpeg source file into 48000hz using tmpgenc xpress?
Or is Besweet the preffer option?
thanks for your reply-------------
djsimonl -
OK, followed above advice,. mpv streas play wit the WMC=P and WMC, byt whether u=i atteno ro uther the DVD (DVD authgoiut tmogenc), as soonn as a hit output/encode, the porgram just crach (no wornig)
I believe it maybe bad odec i have recenly instaled.... any hints,
I HAVE DOMPLETE THIS TASK BEFDORE very weell, so this time has stgumped me,.
just for EG. if the the m2v mp2 ..> MPEG WASNT compliante formmpegs2, how do i check?
Thansk guys, big help. The personal who heklp me gte a FREE "The Best of Borat" DVD i'm authoring (eps from usa, england etc)... 2hrs plus-- HILAREIOUS
Thanks-------------
djsimonl -
Originally Posted by djsim
Dude, if you're using an Australian keyboard or something, turn it back rightside up. Either that or put away the Foster's. -
ok heres the new drama... uponen attempting to push ENCODE, tmpgenc dvd author simple shuts down w/o warning!
I Asume it a codec I; a directhowrecently -- anyone got any idea of which diectshow codecs are bad news?
MUCH APPREIATED!
ps - just to check, what app do i use to anylse my mpeg-2 video which is ready for authoring? Perhaps the input file is corrcupt
PLEASE HELP IT'S DRICING ME NUTE... SPENDING 8=hrs online on my vacatio trying to weork it out, HELP)))))
sim-------------
djsimonl
TMPGEnc Xpress 4.7.4.299 crashes at 50%; audio related
By CasanovaFly in forum Video ConversionReplies: 0Last Post: 28th Mar 2010, 22:20 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
cannot open video only audio (tmpgenc xpress)
By bizt_uk in forum Video ConversionReplies: 3Last Post: 21st Nov 2008, 13:31 -
TMPGEnc 4.0 XPress - audio only no video?
By Trang-Ly in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 12:47 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
