Right people. I am sorting out a little network for a friend tomorrow. Below is what he has.
PC with AOL ADSL MODEM
PC WITH G WIRELESS CARD in another room
Do I just need to by a wireless transmitter? and hook that up to the pc?
Will this be compatible with AOL, I know there are loads of things that do not work properly with it, will this be one of them?
Anyone in the UK provide a link of what I need to buy?
Cheers lads
Russ
A wireless router that is compatible with this wireless card will do it, I was doing the same thing with a Netgear setup for a long time with no problems.
Do I need a special one for AOL though
Best Wireless Utility that can be used with any wireless card
By mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 12:29 -
aol number
By Mr anderson in forum ComputerReplies: 5Last Post: 10th Oct 2008, 06:39 -
Can't install AOL update
By JudgeGarth in forum ComputerReplies: 7Last Post: 2nd Oct 2008, 17:36 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 6th Aug 2007, 23:26
