OK this should easy I have used DVDdecrypter to rip a DVD (DVDshrink failed) and I have a list of files from the DVD:
08/25/2004 11:35 PM 83,968 VTS_01_0.IFO
08/25/2004 11:38 PM 1,073,379,328 VTS_01_1.VOB
08/25/2004 11:40 PM 1,073,567,744 VTS_01_2.VOB
08/25/2004 11:42 PM 1,073,352,704 VTS_01_3.VOB
08/25/2004 11:44 PM 1,073,606,656 VTS_01_4.VOB
08/25/2004 11:45 PM 1,073,328,128 VTS_01_5.VOB
08/25/2004 11:46 PM 399,945,728 VTS_01_6.VOB
Nero doesn't seem to recognize them. What am I missing??? I just want to burn them.
Y
Results 1 to 11 of 11
yadda,
If you must bump your own thread, at least wait a couple of days ...not 90 minutes. Consider this an informal warning.
AUP:
Please try not to "bump" your topic.
Replying to your own topic to get it to the top is annoying. Try to have some patience, this is a bulletin board, not IRC. It may take some time (e.g., one or two days) before someone can answer your query or question. -
Sorry about the bump... How do I create these files????
I have already ripped the DVD and I thought I followed the guide correctly.
Y -
Set dvddecrypter to rip all files on the dvd.
Then use dvddhrink to do movie only.
If you have dvd2one, it will work with your present
structure.
kiki -
Or use dvdshrink straight out, there is no need to decrypt first.
I have never understood why people feel the need to do this. -
I don't know exactly what you want to do, but I'll try to help ya. Assuming that this DVD is non-copyrighted material you can do this:
1.Create 2 folders on your HD, name them as you wish (let's see: A and B).
2.Open DVD Decrypter and select foder A to get your backup. Decrypt the DVD.
3.Open DVD Shrink. Hit Re-author if you want to do that. If it's necessary, hit compression settings to set the amount of compression (this should be at 80% = 80% of the size fo the original file, 20% of compression). Please note that the level of compression at 78%, 75%, 70% (of the size of the original file) means loss of quality, for certain. You can also split the DVD in 2 discs hitting <Set Start/End Frames>.
Backup your files to folder B.
4.Open Clone DVD and select folder B to create a new disc from your backup. That's it.
Best way to burn vob to dvd
By ozstar100 in forum Video ConversionReplies: 5Last Post: 4th Nov 2011, 17:30 -
Converting Mp4 to Vob for a DVD Burn
By murihikukid in forum Video ConversionReplies: 2Last Post: 14th Sep 2011, 02:15 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Burn .VOB File with .SRT to DVD+R DL (HELP!)
By holdenmcclure in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 00:47 -
Want to burn 2 .VOB files to one DVD??
By herbster in forum Authoring (DVD)Replies: 4Last Post: 7th Aug 2007, 22:58
