How can I make a perfect (or almost). back-up of a DVD while keeping the menus? I want the ability to choose subtitles, chapters, etc, just like the original...which programs should I use? Currently, I have DVD Decrypter, DVD Shrink and DVD FAB, and burn eith Nero 6, but ehich way is the best?![]()
I am usung I/O Magic 12X Dual Format writer.
Results 1 to 12 of 12
IMO:
DVD5: DVDDecrypter ISO Read > ISO Write
DVD9: DVDDecrypter or Smartripper to rip to HD, DVDShrink to transcode, Nero Express to burn.
DVDDecrypter ISO Read guide
DVDDecrypter ISO Write guide
DVDDecrypter Rip File Mode guide
Smartripper Rip File Mode guide
DVDShrink 3.17 guide
Nero Express burning guide
is it truw when u make a copy of a dvd u need 2 blanks?
what i mean is
i have finding nemo retail dvd.. yes i bought it! and i wanna make a dopy of it i do have a dvd burner... now will a standard 4.7 gb disc using clonedvd make ane xact copy of it?
or isnt it as sample as that my dvd burner is only 1 week old so im nwbie on how to burn dvd's
backwhacker, you can DOWNLOAD DVDSHRINK from the tools section on this forum. It's a freeware program which is awesome. I didn't know anything until a few months ago when I read about 40 posts on here and found out DVDSHRINK is one of the best programs to back up a DVD. Does it quick and in most cases no noticeable quality loss. You should try it out.
I use DVD Shrink, CloneDVD 2, AnyDVD, and B Recorders Gold 5.
when copying a movie the first thing I do it check the size of it in windows if it's under 4.5 GB then I just use AnyDVD to take away the copy protection and B Recorder to do a straight copy of it, but there isn't that many movies that are under 4.5 GB
Most movies I use shrink to remove menu's and extra and audio I don't want so I get really good qulity and I save it as an ISO image to my HD then after I use Clone DVD 2 to burn the image. -
backwhacker
Ditto DVD Shrink
And welcome aboard
The only problem with dvdshrink is that you lose all the menus unless you do a full-disk-copy. I personally like clonedvd2. You can retain all the menus (I like to use the scene selection and subtitle options) and shrink it down. Another plus is that you can create an iso image so you can burn with dvddecryptor.
I think this was already answered above, but just to make it clear. If it's over 4.5G, you either use two DVDs or get a dual layer burner. Otherwise, shrink it down or loose the extras. -
DVD REBUILDER RULES!!!!How can I make a perfect (or almost). back-up of a DVD while keeping the menus?
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 21:19 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 11:19 -
How to make exact screencaps easily from DVD?
By zee944 in forum Software PlayingReplies: 30Last Post: 8th Aug 2008, 04:06 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32
