How much time should it normally take to convert a file from AVI to VCD? A friend of mine converted a 700MB file using a Pentium Pro in about an hour. I'm using a P3 500. So far every program I've used takes at least 2-4 hours to do the conversion. Am I doing something wrong or is this normal?
Sounds about right for a 500 MHz machine.
BTW, the software that you use and the settings will make a difference."Art is making something out of nothing and selling it." - Frank Zappa -
Not that the P Pro wasn't a bit ahead of it's time, but they maxed out at 200MHz. 2 to 4 times slower than that seems a bit off. Try using the same software. Drive setup also makes a difference. Sometimes going from one drive to another is faster than converting a file and storing it on the same drive.
Nothing can stop me now, 'cause I don't care anymore.
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 05:23 -
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 02:41 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 18:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 01:41 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48
