Results 1 to 20 of 20
I use Record Now Max 4.5. FOr all my burning of DVD-R's.....
DVDShrink does not have a built in burner... It uses either Nero or DVD Decrypter to burn.
I use DVD Shrink to rip and compress to the hard drive, then Nero 6.3 to make a DVD Video Disk. Over 150 movies in the past seven months. I have thought about changing to something new but why fix something thats not broke. I like to have just the main movie in English and nothing else. Skip the menus and extras or other languages.
If Man Made It, Man Can Copy It. -
I burn with VSO CopytoDVD mostly. I started using copytoDVD before Shrink had the burn option, but i do not like the new copytoDVD interface as much as the older version. So maybe i 'll start using the Nero built in burner on Shrink. Assuming it's as DVD player compatible as copytoDVD.
I use DVD shrink to compress and DVD Decrypter to burn the image file.
There is no Nero "built in" burner in Shrink. If you don't have Nero installed on your computer then Shrink can not use Nero to burn.
YES.
DVDSHRINK can automatically link in with Nero or DVD Decrypter to burn the image. If you don't have either installed, then it can't burn.
Regards.Michael Tam
w: Morsels of Evidence -
Nah, this poll is fine, just it wasnt explained well.
Should be
"Do you use DVD-Shrink's built-in burning capability to automatically burn with Nero, DVD-Dec, or do you use other software"
and 3 options to choose: DVD-Dec, Nero, other
well, then its a totally diff poll... yeah youre right, its a moot LOL -
Hi all.
DereX888, you forgot to add CopyToDVD to the list of burning options (its SDK has been added to v3.2).
I usually choose "Hard Disc Folder" as the target, and burn later, at a more comvenient time, with Nero 6.
This enables me to use the computer for other tasks while processing the files in DVD Shrink. -
I use Nero 6 to burn "DVD-Video" from folders I made with DVD Shrink. What I usually do is backup multiple movies into folders, then burn them later.
@ddlooping
Honestly I didnt knew up until now there was a possibility to burn with CopyToDVD in shrink
Thx for the info
Im not much of a user of shrink, some time ago I've actually reached that 'comfortable level' of having all of my software doing exactly what I need it to do, and Im not even following any newer stuff ATM (unless its some breakthrough like dual layer or so ofcoz).
BTW - just to clarify:
I didnt make this poll, I only comment on it here earlier. -
No problem, DereX888, nobody does.
CopyToDVD for me.
CopyToDVD also burn long file name without 'rename' which ALWAYS request from Nero or Roxio.
Otherwise 'one step' back up, I use elby CloneDVD 2 with DVD Region-Free or AnyDVD.
DVDShrink 3.2 to squeeze and Nero 5.5.10.XX to burn (Nero 6 too buggy).
I use Nero and Tmpg DVD author burning utility when I need to burn a dvd with volume name greather than 16 chars.
Hello Mac users
By thoughton in forum MacReplies: 2Last Post: 24th Mar 2010, 21:19 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
FS-4 HD PAL users out there?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 8th Jan 2009, 14:14 -
Xilisoft Users - Some help.
By 4ce in forum Video ConversionReplies: 1Last Post: 26th Dec 2008, 23:52 -
mkv2vob users
By ckamc in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 19:04
