Hi,
confused on how to get from a 6 channel wav to a working dvd-a using discwelder steel. The file burns fine to cd-dts and plays 5.1 on my home stereo and my car (which has 5.1 and will play cd dts or dvd-A).
I took the file and exported it to 6 separate channel wavs in adobe audible, and than imported them to the corresponding channel in discwelder. After burning , my home dvd player (bravo D2) wouldn't play it. It's in 16bit 44khz. Does it have to be 48khz for dvd-A. The manual says it will make it out of several bit and khz values and can mix tracks with plain stereo too.
appreciate some help and education.
My dvd player has played almost everything else (copied dvd's and svcds I've made)
thanks,
jay
Results 1 to 1 of 1
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
How to make such DVD?
By Remyisme in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2009, 20:57 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 16:12 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10
