I cannot get this to work. When I have everything selected and click "Save" frameserver 2.0 does nothing, just displays the frameserver status window with about and stop serving button, back ground is doing nothing, no rendering..none.
These are my steps:
I add my original .avi file to the timeline
I go render as DeBugmode Frameserver (*.avi), template default (no change allowed anyway) in the pulldown
I save the "signpost" untitled.avi to a folder
I choose YuY2 and click write audio as... (have use RGB24 as well)
by this time the window "rendering untitled.avi is increasing in time left and nothing is getting rendered
Even the frameserver status window shows video 0% realtime
I am testing on a 5 second clip
I noticed that the plugin didn't install where the readme file says it should. I have reinstalled to where it says. Perhaps this is an issue although the program does run, it just doesn't do anything.
Any suggestions appreciated, thanks.
can you play the fake .avi file in media player ?
Got it, I don't think the .dll was in the right place - thanks for replying though!
DeBugMode Wax = HitFilm?
By budwzr in forum EditingReplies: 0Last Post: 25th Apr 2012, 00:17 -
Virtualdub framesever to Sony Vegas
By jairovital in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2010, 11:00 -
Debugmode Frameserver questions
By vid83 in forum Video ConversionReplies: 5Last Post: 31st Dec 2008, 18:52 -
Sony Vegas, Windows Vista and DeBugmode Wax 2.0e
By tarrickb in forum EditingReplies: 0Last Post: 16th Aug 2007, 12:29 -
Alternate to debugmode frameserver (for Premiere Pro 2.0)
By foochuck in forum Video ConversionReplies: 6Last Post: 13th Jul 2007, 08:05
