forgive me if this has been asked. I have done some searching.
I need to split some mpeg files. I had some difficulties with mmc presets and ended up with many files that are seven to ten gigs. I want to split them into 4 gigs for burning and archiving. I do not need to author them, nor do I need to preview to split at a specific scene, I just need to cut them at anywhere from 3.5 to 4 gigs. whether they end up as mpegs or vob's I dont care.
Is there a freeware method? I have studio 8 and not only does it take an enourmous amount of time but I often lose audio synch despite the files having proper synch on original playback all the way to the end.
You might try using WinRAR to split the file up into smaller pieces that you can reassemble later.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
aero,
Try the Freeware tool MPEG2Schnitt.
regards,
Moonstomp
https://www.videohelp.com/tools?tool=600#commentsJust because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
Jerky action mpegs
By enfield250 in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Aug 2010, 06:51 -
Easy audio and video stream splitting application suggestions please
By roberta in forum DVD RippingReplies: 2Last Post: 21st Feb 2010, 17:12 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 12:10 -
TubeStick and splitting large mpegs
By benblack in forum MacReplies: 7Last Post: 30th Sep 2007, 15:11
