I have recently bought a laptop which its dvd-player is coded and I can't use it to watch a movie from other regions.
Is there a software or a way that can make my dvd-player region free?
Hello,
There are a couple of places to look:
https://www.videohelp.com/dvdhacks
https://www.videohelp.com/tools
In the tools section check out the region free selection. Also, depending on your model and operating system you may be able to use dvd genie.
Kevin
--You should also get your dvd-rom model number and graphics card model to aid in your searchDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
try this..
there is software wich tells you exactly what drive you have, then you can ind the firmware for it. if there is no firmware, then you have to use software, as dvd region
http://forum.rpc1.org/portal.php -
Some really good suggestions provided by others.
But i prefer using DVD Region Free from dvdidle.com Though this costs (about $40), i have found it to be a great tool. it is guaranteed to work with any dvd drive and software dvd player and also has a host of other features such as macrovision free playing option, play directly main menu or movie etc...
but then again, the choice is yours. usually, people use firmware hacks to make their price region free (as being free), the link is provided by lenti_75. But BEWARE, this can VOID the warranty of your dvd drive.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
How to make a region free disk
By aussierobbe in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2011, 00:25 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
