What is the most simple tool for just cutting pieces from Mpeg files without rendering afterwards. I have a large mpeg file, and the only thing I want to do is just remove some little pieces.
B17
use womble products for ease and speed (no re-encode), which are mpeg2vcr and the much improved and better GUI mpeg video wizard. however, sometimes with womble if the movie file/mpg are too long/big (2hr movie say 5.5gig+) the audio will get out of sync deep into the movie ONLY after authoring process. So, if this happens I highly recommend doing your cut edits directly in TMPGEnc DVD Author and you will be assured of perfect audio sync after authoring to dvd folder. OR, use VideoReDo for mpg cut editing as it tends to never have audio sync issues, even after output is authored to dvd.
Free simple tool to export sections of videos?
By Maoukiji in forum Newbie / General discussionsReplies: 6Last Post: 19th Mar 2012, 13:59 -
simple freeware tool
By agent222 in forum Video ConversionReplies: 3Last Post: 1st Oct 2010, 16:22 -
Simple wmv editing tool
By karebo in forum EditingReplies: 2Last Post: 5th Apr 2010, 05:40 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 12:45 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 03:09
Thanks for all the suggestions, I found my thing!
