  1. Hello,
    I have a question that relates to Authoring software, and .VOB files with multiple audio tracks plus menu
    Extract .VOB files off an existing DVD disk. Note: each .VOB contains two audio tracks, put them on a DVD with my own menus and access buttons.
    After finish I notice that there is no audio. Is anyone know why? Or know how to fix it.
    tmpgenc dvd author only supports one audio track. could you select any audio track when imported the vob(you should use import dvd when importing dvd vobs)? if not you may have to demultiplex the vob or else wont tmpgenc dvd author may "get" the audio.
  3. Balbrick,
    Thanks.
