I'm wondering if this is possible as I live in the UK so want to order some footage in PAL, but I have some NTSC footage already that I might be putting on the same DVD-R??
Anyone tried this?? I don't want my PC to explode if it doesn't work.
I understand that it can be done using TMPGEnc DVD Author, but you need to add them as seperate tracks. Haven't tried it though.
"Art is making something out of nothing and selling it." - Frank Zappa -
I did this using tmpgenc DVD Author and DVDPatcher. I put a couple of PAL clips in the one track then a couple of NTSC clips in their own tracks. I used DVDPatcher to make TMPGEnc DVD Author believe that the NTSC clips were PAL, then patched the VOBs back to their original specs after authoring and before burning. Worked well.
Guide here.If in doubt, Google it.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
PAL to NTSC - when do i select this option whilst editing & dvd authori
By johnnybravo in forum EditingReplies: 6Last Post: 24th Jul 2008, 10:23 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 22:31
