I have an avi the format is :--
Video Compression -- XviD MPEG-4 Codec
Audio Compression ---Fraunhofer llS layer-3 Codec
I am trying to convert this avi to dvd (PAL)
I have used GSpot, and I have all the codecs installed, but I tried VitualDub MP3 Freeze, and saved to wav, and then I used TMPEnc Plus, and found I have no audio at all when converted. The audio is the problem, Please can someone give me any ideas how to make this audio work.
Obviously I am missing something![]()
Did you have full processing mode with no compression selected when you saved the wav file.
Hi Craig,
I have just tried "full processing mode with no compression" in virtual-mp3-freeze, and it just does a few seconds and then goes off, tried rebooting the computer but still the same. -
Does the same thing happen with regular vdub or vdub mod. Are you using freeze because you have had to remove some bad frames. If you saved using direct stream copy before then that explains the problem with the sound, it is still encoded with VBR which TMPGEnc does not like. Another option is to try goldwave.Originally Posted by suzie200294
Hi Craig
The Compression will only work with Virtual Dub Mod, but still does not work in Tmpgenc, still no sound so I will try to use goldwave, or just drop the avi. Thanks for your advice.
I wish they would not use these MPEG-4 Video with MPEG3 Audio, but I will know next time
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 20:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 06:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41
