Hi Guys,
I have a couple of .avi files which i wanna convert into Mpegs using TMPGEnc. The video files have VBR audio and since TMPGEnc doesnt handle VBR audio, i have to extract the audio as uncompressed wav.
I did as mentioned by many here and using Virtual Dub-->Audio-->Full Preocessing Mode tried to extract the audio. But when i try to save the file, it gives me an error "Please check if you have the required codecs". I have Lame mp3 ACM Codecs installed(v3.96.1).
Can anyone please help me on what codecs i am missing out on?
Thanx,
Avinash
If the audio is ac3 then you need ac3 acm decompressor installed.
no...the audio is not ac3 mate. but however i do have the ac3 acm decompressor installed already.
when i extract the audio as direct stream copy, i cant play it in winamp also. it says instal mp3 acm codec.!!! i do have it installed.
will it make a differnce if i instal lthe fraunhofer codec?
-avinash -
thnx dude for the reply.
i installed the fraunhofer codec and now it recognises the compression format as Fraunhofer IIS Mpeg Layer - III and i am able to extract the audio. But the wav file extracted has a 'hiss' sound in the background. is it bcos of the codec? why is it tht even tho i have Lame mp3 codec installed it doesnt recognise the format eventho i heard tht lame is a better codec than fraunhofer.
Will try out with Besweet also.
Virtualdub and audio codec missing.
By nzdreamer55 in forum EditingReplies: 20Last Post: 29th Dec 2013, 23:32 -
No codec available when audio loaded in VirtualDUB
By Bucic in forum AudioReplies: 4Last Post: 27th Nov 2010, 17:13 -
Extracting Audio - Voxware RT29 Codec
By Killer3737 in forum AudioReplies: 1Last Post: 3rd May 2009, 15:06 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03 -
Virtualdub jammed audio codec
By paros in forum EditingReplies: 6Last Post: 7th Sep 2007, 14:58
