ok i know an avi can be converted to 720x480 mpeg1 48hz(vcd). Which is dvd compliant. What i was wondering is...
can i convert avi to mpeg2(svcd) and have the resolution at 720x480? i know that svcd is 480x480. but is it limited to that resolution? i would like better quality but if picture is same length and width, it really distorts it making it look awkward.
Results 1 to 13 of 13
whats even better if someone can list or show me where i can find list of.....
all the dvd-video compliant formats and resolutions. i just know of mpeg1 720x480 -
Does this look familiar?
/Mats -
Click the DVD button under "WHAT IS" in the left-hand menu of this site. You should find what you are looking for.
PB -
ok thanks. i also want to ask another question here, i dont want to waste on another topic, since it might be a dumb question.
I have vcds.... i understand on disk they are DAT files. i want to turn them back to mpeg1 and change the audio to 48hz so i can store them on dvd media.
what is the best way to do that? -
Use VCDGear to extract the mpg from the VCD. To "store them on DVD media", you just burn the mpg as data, but if you want to create a DVD Video from the VCD mpegs, the smoothest way is to use TMPGEnc DVD Author, that takes VCD mpegs as source, and resamples the audio to 48 kHz automagically for you.
/Mats -
Originally Posted by Solarflair
Originally Posted by SolarflairIf in doubt, Google it. -
/Mats -
Of course!
/Mats
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
***HELP*** Needed Enlarging Resolution & Format of Video Clip!
By therock09wbt in forum EditingReplies: 2Last Post: 30th Dec 2010, 17:31 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 13:23 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Suggest a format/resolution to suite ipod, zune, pc, all at the same time?
By vumpler in forum Newbie / General discussionsReplies: 6Last Post: 13th Jun 2007, 22:21
