I bought an OEM dvdrw drive and totally forgot that IDE cables does not come along with it.
Can I use an ordinary IDE cable (that came along with my old cd-rom drive) or does it need to be a specific IDE cable for the new dvd drives?
As long as you aren't still using the really old-school 40 pin cables you'll be fine.
Even old 40-pin cable should work. DVD/CD-drives are only 16.6 Mb/s, 80-pin Ultra-ATA cables are needed only for speeds 66 Mb/s and faster.
Not all system still like 40-pin cabling though. I tried to put a burner in an older PC that had a CD drive on a 40-pin and the burner would not work at all even when alone on that cable. Just replaced it with an 80-pin and it worked. Maybe it's just a finicky drive.
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 14:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50 -
About IDE to USB adapter cable
By AusTaylor in forum ComputerReplies: 7Last Post: 4th Feb 2008, 01:18
