Hi everybody,
Ok...I don't really know where to post this, and I've done a whole bunch of searching...But the truth is...I don't really know what to look for with this idea. I'm hoping somebody can point me in the right direction.
Here's what I wish to accomplish.
I have a whole bunch of DivX movie files that I would like to place on DVD's. However due to thier current size, I can only fit one file per DVD if I converted them to Mpeg <and having over 100 dvds is a little out of the question at this point> I'm using an HTPC for DVD playback, so I'm a little more free to work with different formats.
I would like to put about 12 DivX files on a single DVD-R disc, but I would like to create a menu that will play on a PC that will let me choose whatever file I like. I could do this in HTML of course, but I'm trying to put something together that will run by itself, and not require memory intensive things like Internet Explorer, and the like. I'm trying to avoid the Windows look as well, and a dvd menu would fit the bill just fine.
Is this making sense? Does anybody have any ideas on where to look or what to create this out of?
Any ideas would be appreciated
Xar256
Results 1 to 9 of 9
Moved to Newbie Conversion forum.
You probably need to look at CD menu creation programs. HTML will require a browser of some sort, although it does make the disk a little more universal.
Something like this might fit the bill
http://www.snapfiles.com/get/mediamenu.html
Otherwise there are more here
http://www.snapfiles.com/downloadfind.php?st=cd+menu&search=Search&action=sRead my blog here.
I know it uses a browser, but the following works and your HTML coding will determine how good you can make it look.
I used Media Player Classic to play movies dependent on their selection from a html menu, which is set to autorun when the disc is inserted. Check out my sample (~2MB zipped) http://members.dodo.net.au/~jimmalenko/autorun.zip.If in doubt, Google it. -
Originally Posted by Baldrick
Awsome! This is exactly the type of thing I'm looking for. I'm going to check this out tonight.Originally Posted by guns1inger
Thanks very much!
Xar256
You could also use Adobe Acrobat to do a "full screen, menubar-less" PDF menu screen with hotlinks that open up individual movies (and even put the "player" on the disc!).
Or for that matter, you could even use Powerpoint (Ugh!
). There are many others--Director, iShell, etc. Most of those require a larger investment of time and $$$.
Problem with most are that they really only do single "top-level" menus well, not branching submenus etc, as that requires support for actions concerning the actual media itself. That's where complete CE multimedia applications like VCD and DVD shine.
Maybe Microsoft/Panasonic's "HiMat" or OSTA's MPV specifications will make this easier for all..
HTH,
Scott -
<kicks dirt>
creating a dvd menu
By petarone in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2010, 13:29 -
Creating a DVD with Interactive Menu
By magus2008 in forum Authoring (DVD)Replies: 11Last Post: 20th Nov 2008, 07:33 -
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 09:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
creating a dvd with a menu with different files
By bibitronik in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 21:13
