after i installed an updated firmware for my dvd burner, it screwed my computer up and i had to reinstall windows. anyway, i used dvdshrink to backup a dvd movie and nero is having a problem burning it. after burning for a bit, nero says "Data read error" and stops burning. whats the problem? i successfully burned a CD-R, so what could be wrong? i tried using pinnacle instantcopy, but for the destination, it doesn't let me pick my dvd burner. i used nero before and had no problems burning dvd movies, so any help would be appreciated.
Try DVDDecrypter. It should be selectable with the later versions of Shrink. If it still doesn't work, you may have problems with data transfer from your HD. There are a lot of possibilities why it isn't working.
well i ripped another dvd movie and burned it, and it worked fine... so maybe just that one movie is bad or something? although there are no scratches on it.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
