  1. Does anyone know where I can find a guide to correctly set Video GOP and Video sequence header in TMPGEnc plus conversions. For both NTSC and Pal formats. What I need is a guide that explains the different Video GOP and Video Sequence header correctly for their format(NTSC and Pal), this would be great, thanks.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    PAL max frames in a GOP: 15
    NTSC max frames in a GOP: 18
    If in doubt, Google it.
  3. Thanks Jimalenko, but I know that settings very well. But then what happens if I change them to NTSC GOP 13 or PAL GOP 10???
    That's why I ask if there's a guide.
    What about these settings if alter??
    Number of I picture in GOP
    Number of P picture in GOP
    Number of B picture in GOP
    What good does it do if I change the :
    Output interval of sequence header to 3 or 4 ???
    Where can I get such a guide??
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    tried a web search ?
  5. i got a question relate to tmpgenc GOP..
    i use the Tmpgenc 2.5
    i have a serie it have 20 episode.. i convert 1-20(rmvb) to mpeg but episode 6 when i put in to the TMpgenc DVD Authoring it said the GOP
    here is the message from TMPGENC DVD AUTHORING.
    *The video GOP is too long.
    For a standard DVD it is necessary that the GOP fulfill the following condition:
    Max 36 fields (18 frames) (NTSC format only)
    Max 30 fields (15 frames) (PAL format only)
    i edited the Tmpgenc setting by setting the GOP to 18 and it converted to mpeg now it seem i can drag it without any problem.
  6. Aznmask; what is your question? It sounds like you solved your problem yourself.
    Torex88; if you change GOP size bad things might happen -- it might not play on your DVD player, so on. There isn't any reason to change it.. just leave it alone and everything will be fine.
