I recently upgraded to Nero 5.5.5.1 and got the MPEG-2/SVCD Encoder to burn SVCD from AVI and MPEG files. I had no trouble burning the CDs and the video quality is noticebly better than VCD. The problem is with the audio on AVI files. When I make the SVCD from the AVI, the audio stops completely after about 20-30 seconds of play. And the rest of the video has no sound after that. The same thing occurs in VCD format. I don't have this problem with MPEG files however, just AVI. But the video resolution is better using AVI so that's my preference if I can make the sound work.
By the way, the AVI files play fine on my computer using WMplayer and there is no loss of audio, so I know the movie is ok before the MPEG-2 encoding.
I have had no other problems using Nero burning software; everything works great except for the VCD audio problems. And there are no indications of any system or performance problems, or problems with the original audio/video capture and moving making process. During the burn I have ensured that no other programs are running in the background, so there shouldn't be any resource issues. Is this a known bug? Does anybody have any suggestions?
Any help is appreciated!
Thanks!
Results 1 to 1 of 1
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 12:47 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Need to split AVI due audio problems
By Squid_uk in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2007, 07:35 -
remove audio from AVI problems
By 1031982 in forum Video ConversionReplies: 10Last Post: 19th Jun 2007, 18:34
