hello, i wanted to start a thread for everyone to give there PC hardware details and convertion times using these 2 programs, (or just 1 or the other) - To give use basic knowlege of how fast/slow convertion takes with what hardware.
The Symptoms are:
Converting a Standard XVID/DIVX Movie file around 125 - 135 minutes long on average.
Converting it TO an average 3500 KBS to 4000 KBS MPG2 Standard file with either one of the programs. dont forget to state the speed/quality mode type (EG: high speed -Procoder)
If you dont know the full specs of your PC please just enter the basic specs.
Thanks a lot!!!!![]()
HERES My setup PC:
CPU: AMD 2800XP running at 2.9GHZ
RAM: 256MB DDR333 PC2700
HDD Size and speed: 80GB HDD, 7200 rpm IDE
FILE: DIVX/XVID
LENGTH: 132 Minutes
BITRATE: 4000KBS
SOFTWARE: Canopus Procoder 2!!!!
OUTPUT TO: DVD MPEG2
SPEED/QUALITY: High speed
APPROX TIME TAKEN: 3 Hours 40 minutes
I Think my PC would be a lot faster converting if i had more RAM.![]()
Please state yours, this information could be extremly useful to other forum members.
Results 1 to 12 of 12
It would be faster if you had a second hard drive.
Read the source from one drive, and output the encoded file to another. -
koolaid, Thanks for the info , i didnt know that! im getting a new HDD next week too!
average DVD ca 4 Gig (for simplicity)
DVD rip time 20 min. due to DVD player slowness as compared to HD
conversion time ca 3.5 hrs !
and you say that 2nd HD woul make it faster?
During conversion your HD is on idle speed, far from what it can do.
Nolimit966, you are right, you have too little RAM, more RAM = less HD read/write cycles. -
Something tells me that these would take about the same time, but I would place my bets on Procoder having the better final output. I am always stuck on quality over speed.
Originally Posted by Aznmask
I normally use 2-pass VBR to increase the quality. It takes a lot longer, but I have the cache setting set to 4 GB so it's about 1.6x longer compared to CBR. Also, if you use any filtering like noise reduction it can double the time.
Unless you know all the settings then you can't really make a valid comparison."Art is making something out of nothing and selling it." - Frank Zappa -
Oops sorry... Seeing somebody already played Brainy Smurf up above.Your miserable life is not worth the reversal of a Custer decision. -
here - i did a test for you to compare speeds
https://www.videohelp.com/forum/viewtopic.php?p=1024711#1024711"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks
seems as though
the approx time to convert a xvid or divx 130 minute movie to mpg2 or vob is around 3 - 4 hours
Long Encoding Times - MPEG2 --> XviD?
By onesikgypo in forum Newbie / General discussionsReplies: 16Last Post: 13th Oct 2009, 07:06 -
How to fix long VOB seek times
By aliasx51 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Apr 2008, 12:02
