MB P4P800SE cpu P4 3.2g memories 1g ddr400 ram video card ATI9550 vivo hardrive 120G SATA pci fire wire card, when I capture DV or analog video there so many drop frame , worse than my AMD 650 memories 640 pc 133 80g ide hardrive. both using win xp fro, don't know what do I do wrong at the new unit . Please give me some help , thanks for any help![]()
Look at your taskbar, how many applications are running in the background? If you purchased a computer from the usual suspects (Compaq, HP, Dell, Etc.) there are probably all kinds of 'Features' running. I would suggest you download a program called "End It All", I think it is on the PC Magazine site. If you Google "End It All" you will probably find it and it's free. It will shut down all of the unnecessary applications, you will have to experiment with what can be shut down, you may even crash your computer. But the beauty is, a reboot will return everything to normal (MSCONFIG settings won't do this). I use this before I begin capturing and I drop '0' frames at High DVD quality on a 1.8 P4. Based on your description, you should have no problems capturing.
If it works, don't fix it.
jvc gy-hm 700 drop frame
By seistro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Sep 2012, 12:31 -
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 10:37 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 18:30 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 11:29
